Immediately get 'Call Ended' when trying to make calls while roaming in the US.Can text and use data
Snowdog49
With a Moto G7 Play, trying to make calls in the USA. Re-booted after the flight landed, can use data and text but when I try to make a call I immediately get the message "Call ended". Can receive texts but cannot receive calls. On LTE OK. Any ideas?  Thanks in advance.
@Snowdog49
Great it works..yes, you already connected to T-Mobile
Snowdog49
OK great. I selected "2G" and it started working!  (Not sure how to select T mobile network.)
Many thanks!
Ashley
hi @Snowdog49
try connect   T-Mobile and AT&T and make call on each network and see if works
if not,  connect to T-Mobile and also change network to 2G
still not work?? download voip app TextNow and use it to make calls first for now
@Snowdog49  Try connecting to T mobile and set phone to 2G for voice . Guessing your phone doesn’t have voLTE . If it did LTE should work with TMobile or AT&T
