03-06-2024 05:29 PM
With this forced changed to the new points plan I will be paying more now and I will be switching to Freedom Mobile.
I want to know how do I go about cancelling my Public Mobile plan and account?
03-06-2024 07:13 PM
@GY7802tv , I did the same as well.. I was with Freedom for a long time and now switched to PM. Freedom's 5G speed is worst than 4G/LTE. I am getting a better speed with PM. It's not the greatest. I hope PM's speed will improve once the 5G is fully implemented.
03-06-2024 06:53 PM
You need your account active when you port in order to transfer your number, so I would simply just port it before your PM plan expires/renew.
03-06-2024 05:44 PM
@iamcdn79 I need to give Freedom Mobile my account number?
Typically yes, although they might be able to do it with the IMEI number instead.
03-06-2024 05:43 PM
I just did the reverse. Moved from Freedom to Public this week. Freedom is ok but 5G coverage is not as good. Freedom 5G is slower than Public. I tested it. I ran both providers on my phone (dual SIM) before deciding to switch to Public. I did multiple speed tests around the city. In all of my tests Public recorded higher mbps. (FYI - I live in Calgary, AB)
03-06-2024 05:41 PM
03-06-2024 05:38 PM
@iamcdn79 wrote:How do you port a number out?
Pick your next provider go and sign up and tel them you want to port your number from your previous provider
03-06-2024 05:38 PM
@iamcdn79 you just need yourbPM account number and make sure the PM account is active . Start the port process with new company leaving PM SIM card in the phone . You will get confirmation text from PM to port . You have to reply YES with in 90 mins that’s it
03-06-2024 05:37 PM
Oh I plan to
03-06-2024 05:36 PM
Stop paying your bill. Ask agent to remove your credit card details from the file.
Declare phone lost/stolen. Account will be immediately suspended and closed after 90+ days of no pay.
Toggle Subscribed switch in Payments area.
Port out your number to other provider. Account is immediately closed and you keep your number.
03-06-2024 05:36 PM
Before you leave, at least get the 'bonus' whatever and use it up.
Get every last benefit you can - then leave.
03-06-2024 05:36 PM
03-06-2024 05:34 PM
Porting your number out is the easiest way to close your account. The other is to remove your credit card on file and let it expire and time out
03-06-2024 05:32 PM - edited 03-06-2024 05:33 PM
@iamcdn79 You can port the number out is one way . You can just turn off auto subscribe
Turn auto subscribe off/on
lastly you can ask Support to remove credit card in go front ha account right away by
submitting ticket with support . using the chat bubble bottom right of screen
If that doesn’t work you can always send private message to support .
send a private message To CS_Agents
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
