02-26-2024
01:52 PM
02-26-2024
07:20 PM
computergeek541
Do I need to use an ESim for the 5G plans? I just renewed my subscription to a 5G plan and now my phone doesn't work and says that I'm not activated on the network. Or is there something else I need to do?
02-26-2024 02:03 PM
Just sent them another message - thank you
02-26-2024 02:00 PM
HI @Cmk1
agent usually reply in 2 to 4 hours. Maybe still have tickets from the weekend. Please message them again
02-26-2024 01:59 PM
Thank you, I tried rebooting it and resetting networks and still nothing. I submitted a ticket to CS Agent about 4 or 5 hours ago and still haven't heard back
02-26-2024 01:55 PM
@Cmk1 No you don’t your old sim will work just fine . Just change your network to 5G auto . Also note even with phone set to 4G/LTE you will still see better speeds of 100mbs 4G plan with phone set to 4G/LTE being in 5G plan and also it’s probably best to leave it on 4G/LTE battery won’t drain as quickly and phone won’t run as warm being on 5G
02-26-2024 01:55 PM
HI @Cmk1
no, regular sim works for 5G too
Try to reboot your phone, and click Reset all networks and test again
if still not working, it is a problem on the account, not uncommon for plan change. You will need to check with CS agent. please submit a ticket with CS Agent here:
