2 weeks ago - last edited a week ago by Dunkman
It's been 3 days that I am stuck in an infernal loop of "This may be due to a system error, please go back to the previous page and try again. (Error Code: XXX)". I want to change carriers, but I can't select my plan. What's the problem and how can I fix this?
2 weeks ago
@JessyP - Error code XXX means you will need to use the app to continue activation.
https://publicmobile.ca/en/ab/load-mobile-app
And you should be up and running!
Also NOTE: You may have SMS issues, so as a warning you may want to contact CS_Agent:
Submit a ticket via Chatbot:
⬇️ Click the link for an Agent * ⬇️
* - CS_Agent will typically get back to you within 48 hours. They work 7 days a week from 9 AM to 10 PM EST. You will be required to login to your Public Mobile Community Account to contact CS_Agent. Once you are finished making the ticket with CS_Agent, please ensure that you monitor for one of the agents responding back to you because they may notify you asking for some information via Private Message, in your community mailbox by clicking this link here: Mailbox
