ESIM issue
Ashley1625
I created an account and am unable to complete it as I never got the email for the ESIM.
@Ashley1625
The bot should allow to submit a ticket for customer service help.  Then you can correspond with CSA via the private messaging system.  Unfortunately, it is not live chat service.  It takes times in between correspondence.
If that does not work, you can directly private message CS_Agent:
Ashley1625
How do I start a conversation with an agent and not just a Bot? I think I need the QR code email sent to me again. Or should I create another account? I was charged the $38?
@Ashley1625
If the eSIM was not activated properly, you will need to submit a ticket for customer service agent help.
Click on the chat icon on right corner of website and follow prompts to submit a ticket for CSA
Or you would use the following link:
Ashley1625
hi we have downloaded the public mobile app but it just states ESIM not activating
hi @Ashley1625 did you use Public Mobile app?? if you only try to activate via the browser, you are not done yet.  Please download Public Mobile app and complete the activation and the all will install eSIM for you
if you used the app, then the app would have installed eSIM for you.  Please check your sim manager screen to check if Public Mobile eSIM is there
