Do they have unlimited roaming
Ovo6god1
Hi do you have unlimited roaming USA ?
HALIMACS
To summarize, @Ovo6god1 for US data roaming, it is limited to either the amount purchased in the add-on or the amount indicated in the plan, when on a Canada US plan.
For talking and texting, it’s unlimited, whether purchased as a US add-on or included in the plan.
hairbag1
@Ovo6god1
depending on which plan you select...there's unlimited Cdn and US talk / text while in either place...if that's what you meant ?
HI @Ovo6god1
if you meant the reduced speed data at 512Mbps after regular data are used up, then no, roaming plan does not have that.  I think the roaming partners does not want that happen, or it will cost PM a lot more money
@Ovo6god1
no they don't.   All Canada-US plan does not come with unlimited slow data.
