Community rewards
malikd
When ranking the bottom 50% of “helpers” do people woth accounts that arent active count in that bottom 50% that dont get points or are they not accounted for in the ranking. Basically what im asking is, do you account for the people who dont interact. For example, 51 out of 100 people dont say a peep all month in the community, do one of them make it to the top 50% by chance or are they no longer in the running and the other 49% now make up 100%
9 REPLIES 9
wow that looks like too much work...I commend you lol @darlicious
darlicious
Omg! What a nightmare editing that post to get the columns straight.....jeepers!
darlicious
@malikd
Statistical participation is required to be considered for the secret formula to be applied and calculated. Since it is based on a member's posts/bravos/solutions there would be a basic minimum of 1/1/0 with the least amount of statistics I have seen to recieve a top 50% reward being 1/5/0 from last June or July. This is unusual as the minimum usually averages between 1/7/0 to 1/10/0. This community top contributor's from a year ago contains some good statistics and analysis starting with my post thru to the end of the thread.
https://productioncommunity.publicmobile.ca/t5/Announcements/Top-Contributors-July-2021/m-p/713669/h...
Not all badges have been awarded in the last year which is unfortunate as thats the only way most new users will know if they earned a community reward but it has not appeared in their account.
There are 6 members who have reached the impressive 1000 solution Milestone in descending order:
  1. computergeek541
  2. z10user4
  3. softech**
  4. Dunkman
  5. will13am
  6. esjliv
**softech recently passed the 2000 solution marker a mere 147 days after hitting 1000 solution marker!! z10user4 is the only member with 30,000+bravos/20,000+posts/1000+solutions and was reluctantly forced to take early "retirement"....no golden parachute for all of his hard work!
Here is the monthly badge recipients of the top 3 levels and estimated top 25% and top 50% ( these can be checked for accuracy by looking at the badges in an account.) for 2020/04 thru 2021/07 can be based on adding the top 1%+5%+10%members+oracles=ie. 26+top 25%=26+top 50%=52=104 rewardees (top 50% will all have equal stats which is why numbers in each badge level will not be exactly double the next level.)
Award Month1% ($15)5% ($10)10% ($5)Total Solutions   *
2020-0441316
428                6     *
2020-053912370                5     *
2020-06289462                5     *
2020-07289449                5     *
2020-083810564                5     *
2020-093911553                5     *
2020-102810466                5     *
2020-11278452                5     *
2020-1241417696                5     *
2021-0131013541                9     *
2021-023912315                9     *
2021-033810365                9     *
2021-043810385                9     *
2021-05268325                9     *
2021-06278332                9     *
2021-07268
342                9     *
  2021-08                     2                   6                      8                     455                 9     *   24/41+25='90 $209
  2021-09                     2                   7                      8                     463                 9     *   24/42+26=92  $230
  2021-10                     2                   6                      7                       ?                    9     *   22/38+24=84  $207
  2021-11                     2                   6                      7                     339                 9     *   ?
  2021-12                     2                   8                      8                     484                 9     * 30/51+27=10 $261
  2022-01                     2                   8                     11                    630                 9     * 32/56+30=118 $275
  2022-02                     2                   6                      7                     493                 9     *  26/44+24=94  $221
  2022-03                     3                   7                      9                     745                 9     *  22/35+27=$224
  2022-04                     3                   9                     11                    655                9     *  36/41+32=109 $283
  2022-05                     2                   7                      9                     591                9     *   ?
  2022-06                     ?
* 9-oracles×$20=$180  6×$20=$120  5×$20=$100
lol definitely not far off
Metal1967
 here’s the secret formula…
Meow
I guess only active - with at least one post/bravo/solution are counted and then proper percentage is selected and grouped together.
Unfortunately secret ranking formula is so secret not even PM knows it 😂
Timer
hi @malikd
No one really knows the secret formula used by PM for the ranking.
But from what we believe , only active accounts, who have replied, bravos others or being bravoed will be count.  So, for those who didn't do anything, they won't make it to the pool at  all
