05-23-2022 10:31 AM
Trying to find out why my cell was shut off . My wife uses it when she is at the hospital having her chemo treatments . I will put the charges on another credit card if necessary. Thank You
06-12-2022 02:21 PM
@hTideGnow wrote:HI @CountyDownIeUk while your suggestion is good, I do not think OP needs to get to a point that needs to stop the card yet. Credit card number can easily generated by card generator program anyway. Luckily OP didn't disclose name or address or expiry. Still relatively safe at the moment
So true. I hope @Stu4577 is more diligent in the future and past. Needs to be more cautious
06-12-2022 02:21 PM
@darlicious great idea to just report the post.
Today is a quiet day , everyone slept in. The post was here 2+ hours and no Oracle or CS Agent awares..
Thanks @darlicious
06-12-2022 02:11 PM
9 minutes not bad....since you are usually first on the scene after asking the OP to edit if the info is very sensitive make a judgement call and just report the post so public exposure is limited.
06-12-2022 01:23 PM - edited 06-12-2022 01:23 PM
You should probably edit your entire post unless a CSA or an oracle gets to it first. At the very least put a watch on your credit card for unusual activity. If you do cancel it have your bank send your new card to your branch. You can pick it up in 3 business days rather than 7 to 10 business days with Canada Post.
06-12-2022 12:37 PM
06-12-2022 12:32 PM
Remove your card number. Call TD and put a stop on it and ask for a new number. This is a Public forum and you have just displayed your card number, worldwide.
06-12-2022 12:12 PM
HI @Stu4577 You can also go to a store (Shoppers Drug Mart, 7/11, Shell, Loblaws) and get a voucher. Then use *611 to load the voucher into the account and reactivate the service that way
06-12-2022 11:45 AM - edited 06-12-2022 11:48 AM
@Stu4577 please update your post and remove the Visa # , we are just customer here
Go to your post, top left down arrow click Edit Reply and remove the number
To update the credit card, if you have access to My Account, you can do it yourself. Go to Payment page, manage my card and click Replace this credit card.
https://selfserve.publicmobile.ca/Overview/payment/Make-a-Payment/
Once new card is entered, you need to make a manual payment. Go back to Payment page, click One time payment
if you do not have access to My Account, open a ticket with PM Support by direct message and they can update it for you:
06-12-2022
11:43 AM
06-12-2022
04:42 PM
computergeek541
I am going to change my Credit card to T.D VISA #xxxxxxxx . Ihope this solves the problem.
05-23-2022 11:46 AM
Most likely an autopay failure, going forward (once you sort this one out) You can manually add the funds prior to a renewal so that you avoid this in the future
05-23-2022 10:46 AM
Was your renewal last night? Log in to check your account status or call 611 from your phone. If you suffered an auto pay failure you will need to make a top up payment. Check to make sure your card has not expired and either top up via 611 with your 4 digit account pin # or login to your self serve account and go to the payment page. Choose other amount and top up the difference between your available funds and your plan amount. Confirm and submit your payment. Your plan should automatically reactivate. Log out and reboot.
To contact customer support : Submit a support ticket via SIMon the chat bot Click here
Or if you cannot submit a ticket via SIMon then Click here ....for additional member supplied info.
05-23-2022 10:38 AM
@Stu4577 - what more can you provide for more direct suggestions...?
First, does it show ACTIVE in your self serve account?
If Active, try:
Check for outages in your area:
https://www.telus.com/en/on/outages
If it is Suspended status, you will need to make a manual payment
If your plan still does not reactivate / resume and it shows $0 owing, try adding a $1 top-up payment.
Or try
If still issues reactivating the plan, ask CSA for assistance.
Public Mobile Representatives customer support agents (CSA) can be contacted by either two methods, found here:
