Canada US 40gb plan
Droy
Hello, just switched to this plan
I was just confirming that when I travel to the USA with this plan I still need to buy the roaming add on? Or does this plan not require a us roaming package?  Please let me know
Droy
Thanks for the clarification. I appreciate the help.
Sarcasm @DDM69 ?
Re being unclear about data?
DDM69
@Droy
I see what you mean.  It is not clear if data is included.
@Droy  No that plan includes roaming . When you go to the US just make sure you have data roaming turned on .in your phone settings and that your connect to T mobile and there reports that AT&T is also working again
kb_mv
@Droy This plan includes US roaming. You will not need to purchase the US roaming add on.
