2 weeks ago - last edited 2 weeks ago by computergeek541
I am just wondering if there is any chance I will get a credit since during this billing cycle, my eSIM didn't work.
Thanks
2 weeks ago
Thanks, I just submitted a ticket.
2 weeks ago
2 weeks ago
they just deleted the topic i posted without resolution so I think it's unlikely. I'm really starting to think I just lost $80 trying to switch from TELUS to a cheaper plan. Like, maybe TELUS is doing this on purpose and we're all idiots for chasing the carrot.
2 weeks ago
HI @Haiying
possible, if it is a problem on PM side (not because your device problem or you deleted the esim)
so, ask support agent and see what they say
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
2 weeks ago
probly not...but doesn/t hurt to ask. Click the orange ballon, bottom right side of page to start process of Customer Support. Good luck.
