03-01-2024 02:09 PM
03-01-2024 02:20 PM
I used to have a Samsung Galaxy A5 (2017) and now have a Samsung Galaxy A34. Is there a need to update/reset anything on PM's end on a phone switch? I didn't notify. Same SIM card, similar phone, much less caller ID capability. I used to see business names of most incoming calls, now pretty much none.
03-01-2024 02:16 PM
@PW2 what phone you have. before and now??
Again, PM only send the numbers to your phone with caller id, it is up to your own contacts or the service on your phone for resolving the name , like Samsung phone uses Hiya service for free
03-01-2024 02:13 PM
I've seen this response before; however, I recently switched phones (an upgrade), and used to be able to see a lot more caller IDs than I do now.
In browsing the forums, I've noticed someone say their account hadn't been fully activated, and had been reset by a tech somehow which solved their issues.
03-01-2024 02:11 PM
@PW2 PM only provides number id and not name id
The name you see is either you have it already setup on the contacts or some phone like Samsung has a service to lookuo the name from the number. So, there is really nothing more PM can do with the name lookup
