Agent
CelticBoy
Can anyone please help me to contact cs agent
When I go through PM 'bot' always get 404 error trying to submit a ticket even after clearing cache.
Want to leave message to cs agent
Whomever reads / helps thank you.
People here so kind, helpful.
Means a lot
Brian
@CelticBoy  Yes you can use this direct link
send a  private message   To CS_Agents click
Andy85
Hello @CelticBoy
You will need to submit a ticket to customer support and explain them your situation. Please provide them as much information as possible. The link to submit a ticket is:
Note: they will respond back to your community inbox so check back every few hours. The ticket volumes are higher than usual at the moment due to the Black Friday event
HI @CelticBoy
i think you were using the Chatbot to open ticket using direct message:
Instead ,  please submit a ticket with CS Agent here:
And do you mind to share your problem? maybe we can help
