Add On 400 mins Int'l Calls
danlee
If I purchase the add on of the 400 mins International Calls, is it immediate effect upon payment or do I have to wait, if so how long?
srlawren
@meocon wrote:
@danlee you can log in to your self-serve account to make sure your add-on was there whenever you see it. it means you can use immediately
That's step 2.3 in the guide I linked
@meocon wrote:
It will effect right away for you to use once you have $15.75 balance to cover add-on
In the account the amount showing is always the pretax amount.  The actual payment required only shows up in the payment card statement with applicable taxes added.  The $0.75 you are showing applies only if the line has an AB area code.  In ON, it would be $1.95.
meocon
srlawren
@danlee immediate, but please make sure you follow both steps of the 2-step process:  https://productioncommunity.publicmobile.ca/t5/Plans-Add-Ons/HOWTO-Purchasing-Add-ons/m-p/198974#M22...
meocon
