4 weeks ago - last edited 4 weeks ago by computergeek541
Hello,
I will take my vacation for 3 months out of country, I would like to know if I stop subscription for over 3 months, will I lost my phone number? can I active my subscription after vacation?
Thanks,
4 weeks ago
thanks
4 weeks ago
let's say you renew your regular plan on May 30th. Your plan will go for 30 days...then will Suspend if it's not funded. You then have 89 days to renew that suspended plan, otherwise at day 90, your plan is deactivated. Therefore you have 30 plan days and 89 "grace"days.
Alternative is to downgrade to the lowest plan currently available ($15), then just let autopay happen as usual, even though you're out of the country. You'll be out about ($15 x 3 mos = $45), but no worry about losing your number....even if you decide to stay an extra month or 2. When you get back you can upgrade to any plan that's available at that time.
4 weeks ago
thanks
4 weeks ago
No you can only pause it for 90 days before you lose your number
