04-02-2024 07:02 AM
My phone always showed caller ID but now everyone that calls me is coming up as private number. I have checked all my settings, with no luck. Please help me.
04-02-2024 08:47 AM
agian, make sure the phone has the latest OS update.
Then on your phone, go to Settings and find the "Default caller ID & spam app" , if it is currently set to "None", select the "Phone" app. But if it is already set to "Phone" set it to "None", reboot the phone and then back to "Phone"
04-02-2024 07:21 AM
I have a GOOGLE Pixel 5a I believe its called
04-02-2024 07:04 AM - edited 04-02-2024 07:06 AM
what phone do you have?? make sure you update the phone with latest OS and update all the app on app store
And do you have another phone around to test?? put the PM sim card there and test caller id to confirm if it is a device issue
