eSIM issues
Jemma1967
I’m running an eSIM and a pSIM in my new iPhone. Set the eSIM up with my main number (public) and kept an old number with Telus on the pSim.
Identified the eSIM as my Primary number and the pSim as secondary but it’s not working that way. Only installed the eSIM 36 hours ago. Does it take a while to become fully functional?
wondering why this is an issue? I have to physically turn off the pSim or it automatically uses that number (which has very limited plan and no data).
any ideas? Thank you!
Jemma1967
It was set up fine. If I disable the psim the eSIM works fine.
Jemma1967
I’ve done that. The issues remain do I ordered a Psim and going to try switching them thanks
gpixel
@Jemma1967
I would reverse the process and use Telus as an esim and PM as a regular sim. the esim support at PM is horrendous... at least with Telus you will have piece of mind things will work
hi @Jemma1967 does it work if it temporary disable the pSim? does the eSIM connect? Not sure if the eSIM was properly setup at all
if that shows not connect, please submit ticket with CS agent
