01-25-2024 01:04 PM
my plan is 20gb and i used it all accidentally. i used points for extra 3gb data and its not working since a week ago.
im stuck at 2,4 gb left and cant use any more of it.
01-25-2024 01:10 PM
Try rebooting your phone by powering off then back on and see if that worked.
01-25-2024 01:07 PM
@zagara It could take up to a day for the addon to become active. If it's been a week then there's a problem. You should contact the CS Agent at https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437 to have them take a look. There shouldn't be any more required from you for the addon to become active.
01-25-2024 01:06 PM
@zagara Do you have a data limiter set on your phone ?
