3 weeks ago - last edited 3 weeks ago by computergeek541
Prior to paying for my subscription the public mobile website said my device was ESIM compatible. However, after payment and downloading the app it suddenly says it’s not?’ Also, the app is garbage and it wouldn’t load a support ticket request so I’m having to do this through a web browser. Not impressed public mobile especially if you think I’m going to buy a SIM card. I’d like this issue resolved expeditiously or a refund for my subscription.
edited by computergeek541: as per terms of service, profanity has been removed
3 weeks ago - last edited 2 weeks ago
I recently learned what the cause of my issue was, and I would like to share in case others run into the same problem.
Prior to subscription my IMEI was labeled as eSIM compatible. However, once I paid for the subscription I was told it was not. It wasn’t until I purchased a physical SIM card for Public Mobile that I figured everything out.
Unbeknownst to myself, my phone was locked to my carrier. After calling in to have it unlocked the eSIM kicked in, but because my phone uses dual SIMS I was still running into issues with “labelling plans”.
I ended up deleting the eSIM under secondary as I had chosen to port my number over(had to swap between physical SIM cards to get the port request text) and then through the Public Mobile app added my new physical Public Mobile SIM card number to my subscription.
After this was done my phone calls and data began to work. However, like other users my text messages still don’t appear to be working, and I am still currently waiting on this issue to be resolved.
Hopefully this write up will help others who may be experiencing troubles switching carriers to Public Mobile.
3 weeks ago
I’ve even sent the cs agent a pm and opened a ticket with still no response…
It says it up to date
That phone is certainly eSIM compatible. Is it possible that your phone needs a software update?
iPhone 13 mini
hi @G89
what phone is that? this error usually can be fixed by agent, agent can send you esim qr code to activate
please submit a ticket with CS Agent by direct message:
