Voicemails not saving
vonnieb
My voicemails are not saving. I used to be able to access them just fine and I have not downgraded my account in anyway. I just tried to leave a test voicemail and also discovered my outgoing message has disappeared and replaced by the default one. Then when I went to retrieve the voicemail, it was not there. How do I fix this?
2 REPLIES 2
vonnieb
Thank you Phil. I found those. You're right, it is useful and the transcript is pretty cool. So, if I want to keep the live vm active, how do I go about changing the default apple message? I guess I need to just re-record it?
Phil_Adelphus
@vonnieb   Do you  have an iPhone running ios17?  If so the problem is likely Apple's Live Voicemail which is enabled by default.  The recorded message is a generic Apple voice.  You can access the transcripts by tapping the voicemail symbol bottom right of the phone app.  You can turn off Live Voicemail in settings although I find it useful.
