Unlimited US Calling and Travelling to US
sirjafar
Wanted to know if unlimited US calling applied as well when travelling to the US, or is that only restricted to when I am in Canada? Or would I have to go with a roaming plan?
11 REPLIES 11
@sirjafar wrote:
@ShawnC13 wrote:
A very important thing to remember about purchasing addons is that it is a two step process.  First you will pick your addon and will get charged for it but the funds actually go to Available Funds and then you will have to repeat the process for the money to come out of Available Funds to pay for and activate the addon
How would do I the second part?
All you have to do is go back in to select an addon pick the one you one (and already paid for) and "re-purchase" it the money won't come off of your credit card it will take the funds from the Available funds
mimmo
I find it easier to purchase the add-on via 611. As long as you know your pin and have a credit card on file.
MacMe
sirjafar
ShawnC13
@mimmo wrote:
@sirjafar depending on how often you call the usa fronte Canada the long distance add-on might be better value. 200 minutes for $8.
FYI, aso available and a little cheaper, 400 minutes for $15.
mimmo
The add-on starts as soon as you buy it. It's valid for 10 days. So when you buy it depends on how long you will be in the usa. Typically I buy it the day I leave.
sirjafar
How early do I have to apply for the roaming plan? I am going to the US this upcoming Saturday.
smp99
The Long Distance add-ons (rollover minutes) and the Unlimited US calling option on selected plans (vs CdaWide) only applies while you are in Cda.
The US Roaming add-on is the 10 day option and this works while you are physically in the USA.
mimmo
As mentioned above once you cross the border you need a usa, 10 day addon.
will13am
@sirjafar, if you are referring to the calling feature unlimited Canada and US calling, that's only applicable while in Canada.  There's a US add-on that covers usage while roaming in the US.
