US roaming talk and text
Fritz123
i purchase add on for US roaming talk and text but did not purchase the data add on.
I'll need to turn data roaming off when I enter US.  Will the talk and text still work with
data roaming off?  Thanks
Phil_Adelphus
@Fritz123  Voice calls in the USA require a VoLTE phone because there is no longer any 3G network there. From what I have read you need to have data roaming turned on for VoLTE to work when roaming.  Even if that is not true, you won't be charged any extra for having data roaming turned on because PM is prepaid so anything not already paid for will just not work.  If you don't have a VoLTE enabled phone you may still be able to make voice calls on T-Mobile's 2G but it is not available everywhere.
Joshuawu
PM is a prepaid service. Don’t need to worry about turning data roaming on or off, so there is no possibility to get charged for data if you did not purchase data add-on.
I don’t think that turning off data roaming will affect phone call or text messages.
Neil11
When you arrive in the states you need to see that you're connected to either AT&T or T-Mobile. If not you'll need to scan for and find and connect to either. And yes you will need to have your data roaming ON. PM is prepaid so there will be no additional charges. As long as roaming option is on, you should have no problem while in US.
