03-06-2024 10:04 PM
I bought $15 US Roaming talk and text for my son's phone. He is in US now, he can receive calls from others, but he can't call anyone. How is this going? Thanks!
03-06-2024 10:14 PM
if he doesn't have a volte enabled phone, he's going to have to be using 2G for talk. He can only get by using T-Mobile. If he's close to a cell tower, reception isn't too bad but as soon as he starts moving away from a tower, the ability to talk will diminish quickly.
03-06-2024 10:09 PM
@JZJZ - Does he have data roaming on? If no data add on in the USA, you won't have data services there.
Try manually selecting AT&T / T-Mobile OR setting it to LTE, if it doesn't work, try T-Mobile on GSM / 2G / EDGE.
If none of these work, contact a CS_Agent here:
⬇️ Click the link for an Agent * ⬇️
* - CS_Agent will typically get back to you within 48 hours. You will be required to login to your Public Mobile Community Account to contact CS_Agent. Once you are finished making the ticket with CS_Agent, please ensure that you monitor for an agent because they may notify you asking for some information via Private Message, in your mailbox by clicking this link here: Messages
