Transfer number failed. How to restart the transfer?
Kazma
Hi all, I tried to transfer my number from Fido to Public about 1 week ago, and just realize that I'm unable to receive text messages.
It's probably related to this message I received from Public during the transfer:
Hey, it's Public Mobile. We're having trouble transferring your number. Looks like you entered an incorrect ESN/MEID. Someone from our team will contact you shortly using your original phone number or the alternate number provided. You can also get in touch via our virtual assistant at: https://publicmobile.ca.ada.support/chat
No one actually called and so I believe my transfer is incomplete and the process needs to be reinitiated by Public.
I tried the Chatbot which gave me the "submit a ticket" link but the link doesn't work. How can I ask Public to restart the transfer process?
Thank you all for the help, really appreciated it.
10 REPLIES 10
Petrina
Thank you so much! I really appreciate it 🙂
@Petrina  Here’s how
send a  private message   To CS_Agents
Petrina
This might be a dumb question but how did you contact customer service?
AJ1971
Hi there
I actually messaged customer service with my problem and they successfully ported my phone number on their end but I was still locked out of the public mobile app since it was sending the confirmation code to the old number and didn’t have access to the number anymore and I could not install the e sim. So in the end I had to a buy physical SIM card which customer service attached to my account and now it all works. Hope this helps somehow
Petrina
I made the same mistake while porting my phone number. Any chance I could get number for porting team as well ?? Please and thanks!
Petrina
I made the same mistake!! while porting my phone number. Any chance I could get number for porting team as well ? Please and thank you!
Tonnus
Hi there,
I'm also getting the same issue as I'm porting from Fido to Public Mobile. I also can't submit the ticket and getting an error. Please help I can't receive Text and Calls.
HI @AJ1971
of course.  Sent
AJ1971
I made the same mistake while porting my dad’s phone number. Any chance I could get number for porting team as well ?
@Kazma  It’s best to just use the old providers account number not the IMEI best to ignore it it’s not needed anyway . But no worries I’ll send you the porting team number private message and give them old provider account number and get it fixed
