Switched SIM chip to a different phone and I cannot get data or text/calls to work outside of wifi
mjulian12345
I switched phones and using same SIM Chip, tried to set APN settings but i seem to only be able to text one person. the rest of my texts just say to try resending and gives me an error. Can someone please help I need this phone for my business.
mjulian12345
this phone is not an s7 either is a note 9p 🙂
mjulian12345
already did this but tried doing it again and still nothing. also... apn enable disable is greyed out
@mjulian12345 again, S7 is properly one of those affected phones
You can try also:
go to the APN screen, delete the current APN profile.  Then Add new profile and add according to this, please note case-sensivitve and do not add extra spaces.  Reboot and confirm the new profile is the only one there and active
APN: sp.mb.com
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
         or    default,mms,agps,supl,fota,hipri
           (might need to include DUN for hotspot, please note case sensitive)
APN protocol: IPv4
APN roaming protocol: IPv4
APN enable/disable: APN enabled
                or  Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
mjulian12345
Works perfect in other phone. Its a Note 9p.Sadly I have done the network reset a few times
sim works fine in other phone as well. looks to be an apn setting issue but i may be wrong
@mjulian12345
does it work if you put the sim back to the old phone?
and what model of phone is that?  I wonder if it is a device issue.  Try clicking Reset All networks
also, try putting the sim back to the old phone as well as try on other phone
