Software update
Reagan1
I missed the email ref software update for pictures moms. How do I do that now
1 REPLY 1
@Reagan1
Here is the background information regarding the MMS announcement:
https://productioncommunity.publicmobile.ca/t5/Announcements/Picture-and-Group-Messaging-End-Date-Fe...
if you are using a device that released after 2017, generally, you can simply click Reset All networks or Reset network settings to get the latest APN
Also, you can make a manual update, here are the old and new settings
Old settings:
APN: sp.mb.com
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN Type: default,supl,mms
                             or        default,mms,agps,supl,fota,hipri
New Settings:
APN: sp.mb.com
MMSC proxy: mmscproxy.mobility.ca
MMS port: 8799
MCC: 302
MNC: 220
