07-12-2018 01:04 AM - edited 01-04-2022 06:26 PM
On one of our lines ($30/500MB) the portal doesn't show how much data has been used from the 500MB allotment.
I know where it should be, because on our other line ($40/4GB) it does show.
Is this a known issue, and is there something I can do to show usage?
Thanks!
=aw
07-12-2018 10:43 AM
Thanks. Don't really need another add-on, just needed to know why this one was draining. Probably the new handset has something sucking data in the background. 😞
BTW this add-on was bought in May 2014 🙂 so PM does well. It was easier to manage the add-on when the plan had no data, as data was only turned on when needed. With 500MB, it was easy to burn through the allotment and then tap the add-on. At least half the usage has been since moving to a plan with minimal data. 😞
=aw
07-12-2018 02:35 AM
Its the weird thing in the portal, it will disappeared after data usedup. Just wait for next cycle. Or get another addon.
07-12-2018 02:25 AM
Thank you both. I think that's what it is, as the add-on is slowly going down (or usage of it is going up, I guess).
=aw
07-12-2018 01:20 AM
@ottawa wrote:On one of our lines ($30/500MB) the portal doesn't show how much data has been used from the 500MB allotment.
Thanks!
=aw
IF you do not see your data usage on the overview page then you have used all of your data up and there are a few options.
07-12-2018 01:12 AM - edited 07-12-2018 01:16 AM
It's one of PM's quirks that the data meter disappears when the allotment (either add-on or regular plan data) has been consumed. 500 MB isn't much and can be used up easily, especially with apps running in the background or when you think you're on wifi, when you're actually using cellular data accidentally. On the line in question, are you able to access data without drawing down the data add-on? If not, then the 500 MB has probably run out. FYI, PM data usage always draws upon regular plan data before any add-ons.
