Samsung J7
JimS
I have to replace my phone and need to know if a Samsung J7 work with Public Mobile?
I don't have the IMEI to check it.
2 REPLIES 2
will13am
@JimS, don't use the IMEI checker.  The database is incomplete and contains misinformation.  As suggested by @Taekgun, willmyphonework is far more reliable.
Taekgun
What Sub model of the J7 do you have?  All models will give you a connection with 850/1900, but LTE will depend on which varient you have.
Have look at the following website to confirm if the device you have will work.
http://www.willmyphonework.net/
