Rewards
Zouou
I referred a friend before September 30th, 2022 and as per your Email sent to me, I was supposed to get $5.00 rewards per month for 5 months as well as my friend. Unfortunately, we never received any rewards for the reference. Hoping you will look into this.
Thank you,
Marc
Same problem here,
dabr
@Zouou    Yes, you should both have received the first $5 credit by now if the friend activate before Sept. 30th.  If you don't see anything by the end of this week (PM's system seems to delay this credit for some accounts), then I'd submit a ticket to customer support and ask them to have the credit added to the account.
Here's couple of links to support, try chatbot first.
chatbot:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html
CS_Agent:  https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
@Zouou   First, have your friend to login to My Account and see if he already got the $10 deposited into his My Account as Available Fund.  If there is no such $10 there, it could be that the system missed the referral completely
Even he has the $10, but he do not have the $5 monthly extra, have your friend to open a single ticket for both of you with PM.  They will confirm and they will fix it on both sides.  For your friend to open ticket with PM:
1. If he has access to My account: At https://publicmobile.ca/chatbot.
2. If he does not have access to My Account or have trouble with Chatbot: Private message CS Agent at:
dust2dust
Did your friend get $10 in his account? Did you see the additional referral in your rewards or points?
