2 weeks ago
My account just switched over from the old rewards to the new points rewards. I had two referrals that are still active in the old rewards. Will they be switched over to the new points? I can’t see them in the rewards section.
2 weeks ago
1 pt for every referral, the old ones will carry over to the new system. It works out to a $1 each because 15 pts = $15 bill credit.
2 weeks ago
Yes, they normally are posted shortly after renewal each month. You cannot see details about the referral, just the number of them.
2 weeks ago
@Lindsay5677 - They will be transferred over to points this month.
As long as they are PM customers you will receive 1 points per referral.
You will also see it once you renew your plan. And also soon in the my referrals tab.
2 weeks ago
@Lindsay5677 wrote:My account just switched over from the old rewards to the new points rewards. I had two referrals that are still active in the old rewards. Will they be switched over to the new points? I can’t see them in the rewards section.
Yes, those rewards will be converted. You'll receive 1 point per 30 days for each active referral.
