2 weeks ago
Hello, I ported from Rogers to PM this morning, I can see number is gone from MyRogers app, signal lost as well. Now I can see signal, able to set voicemail etc on PM but not receiving any texts or calls. Kindly help me out it's been 2 hours since I can see signal on PM.
2 weeks ago - last edited 2 weeks ago
your MyRogers app is gone because you put in the PM sim card and they removed the Rogers default app, that is not a sign your port was done
call the porting team. I have sent you the porting support team number. Please check your Community inbox (envelope on top right), check for the number and call
2 weeks ago
try to reboot your phone with the PM sim card once more. (and if you have a Rogers physical sim, remove it, if you have a Rogers esim, disable it)
and test BOTH incoming calls and incoming text
if incoming calls does not work, call the PM porting team to confirm if the port was completed. I will send you the phone number to your Community inbox
if incoming calls work and just not text, then it is another issue, can be fixed easily by messaging support here:
