Oneplus Nord N20 SE compatability
Teeel
Does anyone know if this will work with public mobile?
Thanks
8 REPLIES 8
Vincemtl
There seems to be some kind of issues between Oneplus and Telus each not taking responsibility for why VOLTE. I have a Oneplus Nord 3 and can't seem to get VOLTE to work.
keepasa
Although may work now, the Oneplus's don't seem to be in the list for VoLTE option which we will need once they shutdown the 3G network.  My one plus has the VoLTE option enabled but it seems it has to be approved from the cell provider before it can be fully enabled.  Perhaps as we get closer to the 3G shutdown date, PM will expand the list?
@Teeel
glad it works.  And enjoy!!
Teeel
it worked. I'm connected. thank you so much ❤️
Teeel
thank you. I will give this a shot
@Teeel
please start with Reset all networks and see if it helps.  Some said they might need to Reset it multiple times
If not, then update APN as follow:
APN: sp.mb.com
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
         or    default,mms,agps,supl,fota,hipri
           (might need to include DUN for hotspot, please note case sensitive)
APN protocol: IPv4
APN roaming protocol: IPv4
APN enable/disable: APN enabled
                or  Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
Teeel
ok thank you. having trouble with apn settings and getting it to work
@Teeel
Yes, look like it is compatible.
Your phone has the following bands (Bold are compatible ones)
3G bands HSDPA 850 / 900 / 1700(AWS) / 1900 / 2100
4G bands 1, 2, 3, 4, 5, 7, 8, 12, 13, 17, 20, 25, 26, 28, 38, 39, 40, 41, 66, 71
and you need these bands on PM:
