01-15-2018 06:23 PM - edited 01-04-2022 03:19 PM
I have check the apn and it is fine I used to be on virgins , I received a new number when I enrolled here . I have reset the phone and double checked the pan. Still no data. Able to receive and make calls any ideas. And my apologies if I posted in the wrong place.
01-16-2018 01:10 AM
I have tried the Nexus 4 on Public Mobile before. The APN settings will be set incorrectly out-of-the box/after a factory reset.
About a year ago, here's what I wrote:
With stock firmware/rom on a Nexus 4, data will not work in out-of-the-box state. You need to set the access point manually.
On the Nexus 4, it will shows access points for Koodo, PC Mobile, and Telus. From what I see, the PC Mobile setting should work because the sp.mb.com setting is the same, but it doesn't actually work even after trying to activate it using the selection radio button. If you delete all 3 of the preprogrammed access points, and then add a new one with the sp.mb.com setting, it starts working.
https://productioncommunity.publicmobile.ca/t5/Getting-Started/LG-Nexus-4-no-data/m-p/99592#M18729
01-15-2018 08:44 PM - edited 01-15-2018 08:44 PM
Ah shoot, ok.
I see you've contacted the mods already so that's good, they will make sure all is well on their end then and fix any issues there.
01-15-2018 08:01 PM
It actually put in the one for PM
01-15-2018 07:59 PM
Ok, I know you checked the APN but is it exactly what is listed for PM? I know with my phones I have to add one explicitly because the SIM puts in ones for Telus and Koodo which don't work correctly.
01-15-2018 07:56 PM
Already checked that and did the modification. Should be working from what I read and saw. Got me baffled.
01-15-2018 07:54 PM
Account info says I have data 4 + 2 gig
01-15-2018 07:45 PM
Hi @bwolf!
Welcome to PM!
Just going from memory.... do you have "LTE-only" specified in your settings? I ask because I seem to recall the 4 not supporting LTE out of the box and requiring some fiddling to make it work with LTE, and even then I think it would get just one band (4?)
So see if you can set to "3G" and check if data works then.
Do you remember if you had LTE with Virgin?
01-15-2018 07:44 PM - edited 01-15-2018 07:44 PM
@bwolfwrote:Data is on and I don't think I used my 6 gig of data since signing up yesterday
Login to your self-serve account and make sure data is available to use.
01-15-2018 07:29 PM
01-15-2018 07:05 PM
Thanks I sent them a message about it, at least I can make and receive calls.
01-15-2018 06:56 PM
Voice is working good just no data.
01-15-2018 06:37 PM
@bwolf, is it just the data function that is not working? Do other features like calling work? I am trying to rule out general account failures and related issues. Anyway, if the APN is correct, then the other things I can think of to check are that data is enabled, data usage limits (if set) have not been reached.
01-15-2018 06:27 PM
