Need to return pre owned phone
noftlestephanie
Purchased pre own phone it arrived today and the battery quality is poor how do I return it?
@noftlestephanie   doin't wait, open ticket with PM Support and ask for a refund first.  You can rebuy another one after
To open ticket with CPO related ticket, please message them directly:
**Monitor your Community inbox (envelope icon on the top right) after the ticket is opened.  CS Agent will reply you there
MrSpock
@noftlestephanie
hi you need to contact a customer service agent
you will need to open a ticket, to speak to a customer service agent    Click here you can check for a response in your community envelope top right corner next to your avatar, or if you are having issues with Simon you can send private message to a CS Agent here:  https://bit.ly/2GGCJzH
