a month ago - last edited a month ago by computergeek541
I subscribed Public Mobile and Transported my Number and it worked for 2 days after which my transported number is gone and a new number is assigned by Public Mobile, I dont need a new number, need help.
a month ago
hi@Nickjee
you sure your had incoming calls on your old number in the last 2 days?
Did you get a text from the old carrier, did you reply YES?
and can you receive inbound phone calls, especially from Non-Telus/Koodo/PM phone? If you cannot the port was not done
It could be an incomplete port. PM porting support team can help. I have sent you the porting support team number. Please check your Community inbox (envelope on top right), check for the number and call
a month ago
@Nickjee wrote:I subscribed Public Mobile and Transported my Number and it worked for 2 days after which my transported number is gone and a new number is assigned by Public Mobile, I dont need a new number, need help.
The only way to find out what happened there would be to ask a Public Mobile customer support agent. Please open a ticke using either the chatbot at https://widget.telus.tiia.ai/publicmobile/publicmobile.html or through the support section of the Public Mobile app.
