11-16-2016 09:14 AM - edited 01-04-2022 06:23 PM
Hey all, similar to this thread here:
I have a LG G5 with LTE bands locked out. The phone is unlocked but I'm stuck on 4G. Does anyone know how to activate the LTE bands for this phone?
11-16-2016 01:45 PM
I had to enter in the apn information on my daughters LG G5 from wind to get it to connect properly, after that all was fine.
11-16-2016 01:03 PM - edited 11-16-2016 01:03 PM
Just to make sure the phone is fully functional, could you make a voice call to see if that works, then reboot the phone to see if the LTE setting sticks?
11-16-2016 09:40 AM
11-16-2016 09:31 AM
@Rockdaddy22 - No 4G and LTE isn't the same.
@hummuschips - I was getting 12 down/2 up now I'm getting 31 down/12 up
@jordanharris01 - Thanks for the tips. That code didn't work. I posted the solution above.
11-16-2016 09:29 AM
Also, try typing this into the dialer: 277634#*# then navigate through:
Field test, Model Settings, Network Mode/LTE Band Selection and see what it says.
Do you mean the band itself is locked and restricted from use?
11-16-2016 09:29 AM
Nvm I figured it out. For those who are having the same problem:
Enter this code: *#546368#*XXX# in your dialer where XXX is the phone model number. (I.e. if you have an H831, replace XXX with 831)
Go to Field Test > Modem Settings > LTE Band Selection > and Choose a band. I am using Band 2 and it works with 4/5 bars of LTE instead of 4G. I get 35mbps down/21mbps UP.
Hope this helps!
11-16-2016 09:25 AM - edited 11-16-2016 09:26 AM
Can you do a speed test to see what speeds you are getting? Use the speedtest.net app
11-16-2016 09:20 AM
