I can't send out a text message but can receive text and make/receive phone calls.
JingXu
Hi everyone,
I can't send out a text message but can receive text and make/receive phone calls. I thought it was my old android phone problem, and bought a new android phone. It still doesn't work!
Please help.
Thanks,
JingXu
16 REPLIES 16
@PAULRANG18 wrote:
You likely have exceeded your plan limit for texts.
I think that too. 50 isn't much and a long text counts as more than one message.
@hairbag1 wrote:
There's a known glitch that PM is working to correct...but so far it's still a problem for some users when the Roaming add-on expires.
U.S. roaming glitch only breaks incoming texts.
PAULRANG18
@JingXu wrote:
Still no answer to the problem - not able to send out text message, but can receive text. I am kind of giving up now. Not worth my time anyway. Very disappointed about PM service, it is very bad in my opinion. Since I am on a $10/mo plan, I can live with what I have now. It is my last post here. Thank you all for the helps! Wish you a great holiday!
If you're still interested in fixing it...maybe check the SMSC #. It's like a phone number that texting uses to relay messages. It should be +16475800172 . You can view it somewhere deep in the texting app settings. There's a dial code to get into a tech screen to set it. I don't have that handy. But at least you can look at what it is now.
JingXu
What phone, OS version and app are you using for texting?
ChuckYeah
Since it's two phones, it sounds like @CS_Agent will have to come to the rescue. Unless, the NEW phone was Used?
Creating a support ticket:
Explain your issue to SIMON, seen below:
Use as few words as possible to allow the BOT to understand. Answer his questions until you get here:
Spoiler
Click on "Submit a ticket" and the Moderator team will respond to your concern, usually within 48 hours.
Alternatively, you may send a private message to moderator through the following link :
Contact @Moderator_Team
About @Moderator_Team
Moderator Hours
Monday-Friday: 8AM- 12AM EST
Saturday & Sunday: 8AM-10PM EST
Hi @JingXu
You are correct you have 50 messages
If you are sending mms data must be on and your apn settings m must be correct, even if you don't have data, the provider is using data
Which phone do you use?
Try to change your settings so that you force your phone to send text only messages. Try sending a text
If that doesn't work, contact moderators
If that works, change your settings back and try enabling data. Try sending mms
If that doesn't work, look up the apn setting for public mobile for your phone. (If you can't set it you can ask moderators for help by providing your phone IMEI)
If that works, you're all set
@JingXu wrote:
I am on a $10/month plan. So I should be able to send out 50 messages, right?
Log into My Account / Data and Add-ons to see how many text messages you can send out. If there's nothing there that meaans you've used up you 50 until your next renewal.
JingXu
The data is off now, but I am connected with my home wifi.
JingXu
Never used US roaming service.
JingXu
JingXu
I have this problems for months, but didn't spent the time to solve it. As I thought it was my old cell phone that caused such problem. But now I got a new Android phone, it still doesn't work. That is why I am here to find the help. I just use the standard message app comes with the new phone. Do I need to install a new text app?
hairbag1
@JingXu wrote:
Hi everyone,
Please help.
Thanks,
JingXu
Did you have the 10 Day US Roaming add-on that has just expired ? If so, your texting function will work fine tomorrow. Cycle phone off / on occasionally throught the day.
totalUser
I'm assuming you are not on the 10 plan which includes 50 outgoing messages.
Also are those mma messages you are trying to send, is your data enabled?
totalUser
How long had this been going on, when did the problem start, did it ever work?
Which app are you using for messaging?
Can you install couple of other apps temporarily to test.
