I can't make or receive calls
CHETHYA1989
14 REPLIES 14
@CHETHYA1989  you cannot make and receive calls on the A10s as well?
do this
Change the Preferred network type or network mode to 3G only or WCDMA only
Check if the phone can connect under this settings.  If it connects, check Data, check incoming and outgoing voice calls and check incoming and outgoing sms
let us know the result
CHETHYA1989
I have the same issue with my Samsung A10S as well.
CHETHYA1989
Yes I am new to Canada
Dual sim will be seen in the sim slot. Very few Canadian market providers deal with dual sim. Many international markets do. It's a stupid North American thing. A sim slot could also double as an sd card slot.
You take your model number and search it and find a site called gsmarena in the results. Then for the A10s you'll see it says International and also LATAM (Latin America). Some models might not give that detail.
@CHETHYA1989 we need to Google the specifications with your phone model
You A10s has both 3G bands needed for voice so it should work.  And data should work ok with the 4G bands this phone has
CHETHYA1989
Hi where in the phone can I get the above information
@CHETHYA1989 that's is an A10s dual simz not Canadian model but should be much better
CHETHYA1989
My current phones model number is SM-M025F/DS
That phone should be fine. Again, are you new here?
CHETHYA1989
Hi I have another phone does voice work on model SM-A107F/DS
dust2dust
And how about the other question...did you just recently sign up? Can you give us the exact model number? Like SM-...M02...
@CHETHYA1989 your phone does not really compatible with PM network
this is your phone spec
3G bands HSDPA 850 / 900 / 2100
4G bands 1, 3, 5, 7, 8, 20, 28, 38, 40, 41
PM uses 3G for voice and you dont have 1900 on 3G which is the problem for your voice. 😞
As FYI, this are the bands used on PM
CHETHYA1989
Mobile data and SMS work. Phone brand Samsung M02
@CHETHYA1989 give us more info, did you just join PM?
does mobile data work?
what brand and model of phone you have??
