3 weeks ago - last edited 3 weeks ago by computergeek541
3 weeks ago
@LP9 - I have sent you a Private Message for the porting team to call. It is in your top right corner or maybe hidden within your avatar with a ( 1 ) on it.
Please insert your old SIM card to reply to their second port of YES and keep it inserted till your old providers SIM has no service.
3 weeks ago
If your number didn't transfer over use the chatbot or use a direct link to submit a ticket to a Public Mobile CS agent.
After you submit a ticket then check your inbox by clicking your avatar and clicking messages.
