Changing subscription
Cathy15
I have a $40 a month now but see they are offering  a new $40 month for a Canada US plan . With this plan can you make calls while in the US
9 REPLIES 9
@Cathy15 wrote:
Do you know if it is unlimited talk in the us
Yes, the calls are unlimited.
Cathy15
@Cathy15   You need to have data roaming turned on and there are no extra charges.
Cathy15
Do you get extra charges for roaming
Phil_Adelphus
@Cathy15   Yes, as long as your phone is capable and enabled for VoLTE on Public Mobile.  This is because the USA no longer has any 3G networks so the phone has to be able to use VoLTE (Voice over LTE) for voice calls.  The only other option in some areas is if you can connect to T-Mobile on 2G where it still exists.  Data and texting should still work regardless, however.
Cathy15
Do you need to have your roaming on while in the states
JoyLuck
@Cathy15
Yes, on the Canada - US plan you can make calls, text and data while in the US.
Dunkman
@Cathy15
Yes, you can make calls, text and use data while roaming in the USA.
You are welcome to change plans to the US-Canada plan.  We recommend change at next renewal date since PM does not pro-rate plans if you change plans earlier. No refunds.
TheSterlinger
Yes, with that plan calls can be made from Canada and the Unites States.
