2 weeks ago
I want to change my $35 plan for 1.5G to the $29 for 40G
do I loose existing rewards by going to a different plan ( friends referral)
2 weeks ago
2 weeks ago
Your referrals stay with you as you change plans so you don’t have to worry about losing them.
2 weeks ago
@Guy8 - You do not lose any referrals from Refer-a-friend when you change plans.
Also I would recommend to use Change On Renewal so then your new plan will start on your renewal date listed in Payments or in your Home Page / Overview in My Account so then you don't lose money.
If you need it ASAP and don't need a refund use Change Now.
