Changing plan
Lhaha
I would like to change my plan to
$25/month with a 90-day subscription,
when I go to change my subscription , it shows like this:
I don’t know if I click on “change on renewal “, is there two options I can see? Just don’t want make mistake to change to $29/month (:
thanks  
2 REPLIES 2
fixin1
@Lhaha - When you click on "Change on renewal" there will be the 30 day option for $29/month or the $25 / month ($75/90days) plan. You can chose between those two options and for the 90 days plan you get 60GB upfront for 90 days instead of 20GB upfront for 30 days.
@Lhaha
click on it and you will be offered two choices , 90 days and 30 days
You will get similar screens like below, except yours would be a different plan:
https://myaccount.publicmobile.ca/en/account/plan/change-planhttps://myaccount.publicmobile.ca/en/account/plan/change-plan
