Changing phone number
Djh444
if I want to change my current phone number is it a simple process that I would take care of my self, and if so is there a charge for number changes?
HALIMACS
@Djh444
Changing your number is easy, but why?
Unless you are trying to avoid calls from a particular person(s) or moving to another calling area and are seeking a more 'local' number, if the only reason you are changing is to avoid calls from certain spam or telemarketers, they will inevitably 'find you' on the changed number.
Still, the option is easy to do and choice is yours.
@Djh444  - changing your phone number is quite an easy process, you can do this yourself in your Self Serve account. And there are no charges for you to do this.
You can change your phone number up to 4 times every 30 days after you’ve activated.
To change or transfer your number after activation, go to your Self Serve Account here and:
  • Select the “Plans and Add ons” tab
  • Click on “Change Phone Number
