2 weeks ago
Can I change my old plan $25 to the new $21 plan because of force reward changes?
Friday - last edited Friday
There is a $19 4G 1GB plan that just became available to current subscribers today. I am going to renew to this plan. I am still hoping to get a cs_agent to switch me to the $21 4G 3GB plan.
2 weeks ago
Hello @Ayr38
If @fixin1 doesn't work, the only other option is... since legacy rewards is now gone and nothing is tying you to stay here, is to port out to another service. Yes, a bit of a pain and YES it will cost you the cost of another SIM card and whatever the lowest amount of their service will be however, do the math. You'd earn that back within a few months and have the plan you want for a VERY long time. Good luck to you.
2 weeks ago - last edited 2 weeks ago
@Ayr38 - You will have a 50/50 chance by CS_Agent. CS_Agents use Change Now instead of Change On Renewal so you may lose the rest of your month. Don't get upset if they deny it.
Contact CS_Agent here:
Submit a ticket via Chatbot:
⚠️ Public Mobile is Experiencing longer support wait times currently! Do Not Reply back to CS_Agent after submitting your ticket unless you solved it! Click here to bring up the Article! ⚠️
⬇️ Click the link for an Agent * ⬇️
* - CS_Agent will typically get back to you within 48 hours. They work 7 days a week from 9 AM to 10 PM EST. You will be required to login to your Public Mobile Community Account to contact CS_Agent. Once you are finished making the ticket with CS_Agent, please ensure that you monitor for one of the agents responding back to you because they may notify you asking for some information via Private Message, in your community mailbox by clicking this link here: Mailbox
