Cannot activate eSim or cancel transaction
D3rby
It has been 2 days and each time I try to activate the eSim - the transaction fails. My credit card has already been charged for the e-Sim is there any way to get technical support or cancel the transaction and request a physical SIM card?
hi @D3rby  you were trying or you used?
 if you have not used the app, the activation was not done.  Please download and use it
if you already used it, then best to get agent support is via message here      https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
D3rby
Yes I am trying to use the App. I have tried for 2 days to contact Customer Service - but I keep getting a message that no agents are available. 😥
hi @D3rby
have you been using the app to activate? if you just using browser to activate and not the app, you are half completed with the activation
if you have used the app, ask support agent to  help activation or to help cancel.   please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
