Can't set city for address change
fbuster1
I'm trying to change my mailing address but it won't let me set my city (Surrey, BC). It says it's an invalid city.
Yummy
Address does not matter to PM.
Pick any close by your hometown.
Please select Vancouver.  The Self Serve system will for reasons that I can't explain will only allow customers to select cities within the pre-defined list.
@fbuster1   yes, the city list does not have all cities there
Just pick one close to you. No worry of doing this, the address is only use for record keeping only.  it is not used for credit card validation
dust2dust
The mailing address has no effect on anything in the system. Choose any city if you feel you need to change anything.
