2 weeks ago - last edited 2 weeks ago by computergeek541
I haven't been able to receive pictures or videos or even send them for awhile now can anyone assist me
2 weeks ago
This is for android phones.
APN: SP.MB.COM must be capital.
See if your phone has the following. If not, delete and add the below
APN: SP.MB.COM
MMSC proxy: mmscproxy.mobility.ca
MMS port: 8799
MCC: 302
MNC: 220
APN Type: default,supl,mms
or default,mms,agps,supl,fota,hipri
See link below for reference.
2 weeks ago
@Donron88 - You may need these devices for MMS:
Make sure you Update your device to see if it will make a difference.
On android follow these steps from help article here to change APN settings: https://www.publicmobile.ca/en/bc/get-help/articles/set-up-data-on-an-android-phone
Next, check your APN settings (Android Phones Only):
Hope this works!
If it doesn't and your phone is listed please contact CS_Agent here:
⬇️ Click the link for an Agent * ⬇️
* - CS_Agent will typically get back to you within 48 hours. * CS_Agents are at load due to iMessage activation issues so it may take longer than 48 hours. * They work 7 days a week from 9 AM to 10 PM EST. You will be required to login to your Public Mobile Community Account to contact CS_Agent. Once you are finished making the ticket with CS_Agent, please ensure that you monitor for one of the agents responding back to you because they may notify you asking for some information via Private Message, in your community mailbox by clicking this link here: Mailbox
2 weeks ago
I experienced exactly the same issue month ago, actually Public mobile updated months ago, please update to the following APN parameters, pay attention to the APN type part.
Hope this can help you out of there
APN: sp.mb.com
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
(might need to include DUN for hotspot, please note case sensitive)
APN protocol: IPv4
APN roaming protocol: IPv4
or Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
