03-06-2022 02:30 PM
The email used is not valid. I can’t get into my account without changing my email which I can’t.
03-06-2022 02:49 PM
HI @Nickbistheman72 Have PM Support to change the email address used (the login for My Account) as well as reset password for you together. Click on the Bubble or directly at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
If you have problems submitting a ticket, you can also send a private message to the moderators (but this can take longer):
03-06-2022 02:43 PM - edited 03-06-2022 02:44 PM
If you DO NOT know or can't access the e-mail used to activate, you'll need to contact the CSA's, confirm that you are the account holder, then request they change the e-mail address to enable you to regain account access.
To contact a Customer Support Agent, there are 2 methods (recommend using #2, and say "Forgot e-mail/security questions")
03-06-2022 02:41 PM
When I got phone hooked up the email used was not the right one. I do not have that email, I need to put the proper email in for access but I’m unable.
03-06-2022 02:39 PM
Did you try to use the Forgot Password feature @Nickbistheman72
You can also use the security questions to regain access.
Make sure you're using the correct e-mail address. Look back in your e-mail and find the "Welcome to Public Mobile" e-mail to be sure you're using the correct one.
