Bought a wrong add-on
Huan
  • I accidentally bought wrong add-on of US roaming data, how could I change to canada data or cancel it?
  • thank you!
7 REPLIES 7
hi @Huan
keep checking this private inbox page, they reply within 1 to 2 hours
In case you want to check what you sent, here
https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage/tab/outbox
@Huan  They  usually reply with in the hour sometimes longer . Just keep n eye on your community inbox for a response
or use this link to it ( community in box )
Huan
Thank you! I submitted a message, but I can’t find it and have no idea where I can find any response
hi @Huan sorry, PM support model is different, no call center to call but just via messaging. Please submit ticket by message
hi @Huan PM is prepaid carrier and usually do not provide refund.  But support agents usually will help ,  please submit a ticket with CS Agent here:
Huan
Thank you! I prefer to a real agent? But I failed to find a suppprt number
@Huan  You can submit ticket with support and see if they can reverse it for you
send a  private message   To CS_Agents
