Account is suspended and I forgot my pin
Rituwalia
My account is suspended and I cannot activate it because I forgot my 4 digit pin.
2 REPLIES 2
Meow
You can always use self-serving account through web browser. And while in your account you can update your PIN!
But if you forgot your email/password then only agent can help you IF password reset does not work for you properly.
To contact CSA-agent, there are 2 methods:
If ticketing does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking Here
Watch for envelope in top right corner. It will show Number of unread emails.
