4 weeks ago - last edited 4 weeks ago by computergeek541
I am now with public two months and after my first month of troubles I thought I would be fine. My plan rolled over may 9 but o can’t get access to data all I can do is make calls. What am I missing?
is this how it will be forever, I’ve not had service the first two weeks because I ported and now this. When will I have peace
4 weeks ago
hi @Cregdt
try Carrier update first, and try Reset network settings
if you have another phone, test the sim in another phone
if you still cannot have data access after trying all above, you need support agent's hep. please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
4 weeks ago
I have an eSIM so unable to remove
4 weeks ago
iPhone. My plan was renewed and my card debited
What phone do you have? you have another one to test the sim card?
and did you check if you have a data limit on your phone?
